Firmware installation using FlashTool failed on RAY!
Rubel
Dear Experts,
During using "Pimp my ROM" software, my RAY(4.1.B.0.587, rooted) restarts. Then i was unable to start any application software, it always shows error: "unexpected error".
For this i want ro repair my phone by using SUS/PC companion.
1st i tried Sony Update service (disable antivirus, full charge the battery) but failed.My phone was not power up after this operation.
Then i used PC companion and it also failed. It shows: Sony Update Engine Failure (error 100)
Then i tried Flastool (v0.9.13) with official ROM(4.1.B.0.587).
Log:
13/058/2013 10:58:21 - INFO - <- This level is successfully initialized
13/058/2013 10:58:21 - INFO - Flashtool Version 0.9.13.0 built on 2013-06-04 22:50:00
13/058/2013 10:58:26 - INFO - Device disconnected
13/058/2013 10:58:43 - INFO - Selected ST18i / 4.1.B.0.587 / CE_1252-3693_ForsakenNGL
13/058/2013 10:58:43 - INFO - Preparing files for flashing
13/058/2013 10:58:53 - INFO - Please connect your device into flashmode.
13/059/2013 10:59:01 - INFO - Device connected in flash mode
13/059/2013 10:59:01 - INFO - Opening device for R/W
13/059/2013 10:59:01 - INFO - Reading device information
13/059/2013 10:59:01 - INFO - Phone ready for flashmode operations.
13/059/2013 10:59:01 - INFO - Current device : ST18i - BX902ZD10Q - 1252-0948_R1I - 1248-9545_4.1.B.0.587 - WORLD-i_4.1.B.0.587
13/059/2013 10:59:01 - INFO - Start Flashing
13/059/2013 10:59:01 - INFO - Processing loader.sin
13/059/2013 10:59:01 - INFO - Checking header
13/059/2013 10:59:02 - INFO - Flashing data
13/059/2013 10:59:04 - INFO - Loader : S1_Loader_Root_773f - Version : R4A066 / Boot version : R9B031 / Bootloader status : ROOTABLE
13/059/2013 10:59:04 - INFO - Disabling final data verification check
13/059/2013 10:59:04 - INFO - Processing kernel.sin
13/059/2013 10:59:04 - INFO - Checking header
13/059/2013 10:59:04 - INFO - Flashing data
13/059/2013 10:59:06 - INFO - Processing fota1.sin
13/059/2013 10:59:06 - INFO - Checking header
13/059/2013 10:59:06 - INFO - Flashing data
13/059/2013 10:59:06 - INFO - Processing fota0.sin
13/059/2013 10:59:07 - INFO - Processing adsp.sin
13/059/2013 10:59:07 - INFO - Checking header
13/059/2013 10:59:07 - INFO - Flashing data
13/059/2013 10:59:09 - INFO - Processing amss_fs_urushi.sin
13/059/2013 10:59:09 - INFO - Checking header
13/059/2013 10:59:09 - INFO - Flashing data
13/059/2013 10:59:09 - INFO - Processing amss.sin
13/059/2013 10:59:14 - INFO - Ending flash session
13/059/2013 10:59:14 - ERROR - [COLOR="Red"]ERR_SEVERITY="MAJOR";ERR_CLASS="MEMORY_CLASS";ERR_ STATIC="HASH_VER";ERR_DYNAMIC="Block verification failed";
13/059/2013 10:59:14 - ERROR - Error flashing.
13/059/2013 10:59:14 - INFO - Device connected in flash mode
13/059/2013 10:59:15 - INFO - Device disconnected
13/059/2013 10:59:17 - INFO - Device connected in flash mode
It is also failed.
Now my phone is totally dead!
I am very warried about my phone`s hardware, is there any problem in ROM?
Need help very urgently!
4 REPLIES 4
Re download the ftf file and flashtool and start all over again, make sure to charge it for 30min
Rubel
Dear uliwooly,
I have tried in different PC, different version of flastool and different .tft file but all are failed!
One thing i should share:
My phone can connect to flash-mode without pressing volume down key!
Plz reply....
Rubel
Dear uliwooly,
Now my phone can connect flash mode as normal way.
But still now i can not able to install firmware in my phone. Every time is shows error during the installation of firmware from pc to phone by using repair (PC companion)
Could you elaborate on the error? what if you try a different PC?
