x
Firmware Backup via PC Companion
Rapperman1
Just purchased the C6906 and notice that the firmware it arrived with is 14.4.A.0.108 (Android 4.4.4).
I've installed PC Companion and both the app and the phone have notified me of an available update.  The phone itself is reporting the update to be 14.4.A.0.108 (approx. 2mb's in size) which makes no sense to me since it's already installed on the phone.  PC Companion has identified and apparently downloaded the available update as 14.5.A.0.242 (Android 5.0.2).
I noted that there are a series of steps that PC Companion performs as part of the update procedure.  I cancelled the procedure prior to the start of the third step which appears to be the actual flashing of the firmware because I wanted to check the forums here and at XDA for opinions of its stability.
Feelings on the new firmware tend to be mixed overall and that has caused me some concern, and I've yet to find the C6906 variant of the firmware the phone currently has installed (14.4.A.0.108) in the event I want to rollback.  The fact that this particular firmware is reportedly easy to root appeals to me since I root all of my android devices.
My question is this: I've done the research and found that PC Companion backs up firmware before updating the phone, placing the necessary files in a folder labelled "blob_fs".  But what isn't spelled out is whether this folder contains a copy of the device's existing 14.4.A.0.108 firmware or a copy of the newly downloaded 14.5.A.0.242 firmware which I cannot seem to locate on my computer.  Does PC Companion push it to the phone at some point during the procedure?  If so would a factory reset or a repair done thru PC Companion eliminate the update file from the phone?
10 REPLIES 10
@Rapperman
It will ,temporary, stored the new update.
Rapperman1
So the files currently stored in the "blob_fs" folder is the new update?
Correct
Rapperman1
Hmmm... to your knowledge is there a way to backup the firmware currently on the device?
If the phone has the latest update then run PCC > repair the phone > it will start downloading the softare
@Rapperman
it will only download the software it won't create a backup like the iphone or some sort of image.
Are you trying to create an FTF file?
/t5/Xperia-Z2/How-to-manually-update-downgrade-root-2014-Xperias/td-p/593459
Rapperman1
Creating an ftf would be great but SUS is no longer available.  I have been able to find no other way of backing up my device's firmware.
And no, I have not yet updated my Z1.  It still has 4.4.4 on it, and that is what I would like to have a backup of.
There isn't a way to do so. but keep checking the XDA forum. @Rapperman
Rapperman1
Thank you for taking the time.  I appreciate it.
