try to remove all fingerprint setups, restart the device and clean the sensor,
re setup the fingerprints.
here's some tips:
1.) register twice the most common print you use,
2.) find a part of your fingerprint with most prounouced lines, that is still comfortable to unlock the phone, for me I use the lower part of my thumb almost to the joint.
3.) try to test the fingerprint while you are on safe mode
Hi @Didd,
I'm very sorry to hear you are having some trouble with your new Xperia X Compact.
I'd recommend that you start with what @nolramlb suggested and remove and setup your fingerprints again. Is there any change if you try what he suggested?
Before registering any of the fingerprints again, use a clean, dry cloth to wipe of the power key (the sensor) as well as your finger.
There are also a few thing that can affect how well the sensor recognizes your fingerprint. For starters, make sure there isn't any dent or scratch in the phone and there isn't anything blocking the sensor.
What can also affect the sensor is the general condition of your skin, such as dryness and cuts. The using of lotions and oils as well as sweating can also cause the sensor to not recognize your finger.
Please let me know how it goes!
