Hallo everybody
My device works already with KitKat.
Now I have problems with the file system.
If I add a folder with the File Commander in e.g. Internal storage/Music, I can’t see the folder on the PC connected with USB. Neither “refreshing” nor disconnecting/connecting helps.
A folder created with the PC can be seen with the File Commander.
Can anybody help?
Try to copy content to the folder you have created in the file manager and see if it appears when you connect the phone to the PC.
Which operating system do you have on your PC?
Hallo
If there are files in the folder, I can see them on the PC (W7).
But it's impossible to copy data from the PC with USB-connection to the SD-card. Is this normal?
No,that is not normal,you should be able to move files as you wish.Try to reformat your micro SD card.
