Facing problem with Soft keys ? Need help
Hi everyone,
I'm using Xperia Mini for the past 1month & sometime I'm facing a problem with my soft keys ( Back & Settings touch keys ), which is automatically working. I cannot able to open any Application, it automatically comes back to home screen (Back key keeps on Vibrating) .. Does anyone facing this problem & wat's the solution ?
18 REPLIES 18
Thanks a lot friends. Today i will try this and tell if my problem is solved or not.
Markus1
Leader
That is indeed the way to go. If it won't solve the issue though, the phone must be examined and repaired at a service center.
santam1
sure!!
I re-installed the OS in my mobile using the Sony Ericsson Updater. It downloaded the OS and installed in my mobile.
But, the problem persists Slightly_frowning_Face
santam1
mmm....do you use any mobile cover or pouch something like that?? but as mentioned by @devaruban it seems after the re installation of os his issue has gone so I suggested that repair!! and your also using the latest firmware..and i'm also using mini haven't got this issue!! I would request you to contact your regional SE customer support here's the link for numbers... www.sonyericsson.com/cws/corporate/common/contact/phonelist
Sriram, please you just go to some authourized sony service centre & format your mobile. I hope that you won't get that problem again.
Rag143
Hi I am facing problems with my soft keys on my Xperia p since I updated software, soft keys pressing automatically and it's really hard for me to use handset
& photos are invisible in albums phone is too slow
Kindly help to get rid of this problems
Rag143
The right soft key is not at all working n home key and left soft key partly working
How to rectify it????????????
alexrx
Enthusiast
@Rag143,
Repair/re-install the latest software using Sony Update Service.
Sony Update Service
Keep us informed.
