Hi everyone,
I'm using Xperia Mini for the past 1month & sometime I'm facing a problem with my soft keys ( Back & Settings touch keys ), which is automatically working. I cannot able to open any Application, it automatically comes back to home screen (Back key keeps on Vibrating) .. Does anyone facing this problem & wat's the solution ?
Thanks a lot friends. Today i will try this and tell if my problem is solved or not.
That is indeed the way to go. If it won't solve the issue though, the phone must be examined and repaired at a service center.
sure!!
I re-installed the OS in my mobile using the Sony Ericsson Updater. It downloaded the OS and installed in my mobile.
But, the problem persists
mmm....do you use any mobile cover or pouch something like that?? but as mentioned by @devaruban it seems after the re installation of os his issue has gone so I suggested that repair!! and your also using the latest firmware..and i'm also using mini haven't got this issue!! I would request you to contact your regional SE customer support here's the link for numbers... www.sonyericsson.com/cws/corporate/common/contact/phonelist
Sriram, please you just go to some authourized sony service centre & format your mobile. I hope that you won't get that problem again.
@Rag143,
Repair/re-install the latest software using Sony Update Service.
Keep us informed.
