hiii friends.. recently i have purchased a sony ericsson xperia neo v.. very good phone. good display, mobile bravia engine is very good. but i am facing a problem with hd games. my phone unable to display proper graphics in games..it always displays black and white shadow in every graphic detail in hd games like assasins creed hd, spiderman total mayhem hd, brothers in arms, asphalt 6 hd and much more. please help me...what is this problem....guys, please respond if you are having same problem with sony ericsson xperia neo v...
e.g. spiderman total mayhem hd
re install ur android by pc companion and try games after it.
I am also facing the same problem. System displaying Software is up to date when tried with PC Companion.
Not able to run HD games
Somebody please help
Regards,
Pramod
Dear Jayasmi,
Check the apk files your using.
Each smartphone is compatibale with different versions of apk files.
Somebody needs to be made this standard. It should work like a PC games despite of different hardware there is same setup files for PC Games.
However this does not work in smartphones gaming.
Regards
Pramod
hiee frnds ......
i hve download assassins creed game ...n itz working i can see the starting trailer n whn ever the original game starts ..screen goes black with clear sound.. and with BIA2 game also i found same problem ...do i need to do any settings ??wats d use of gpu 205 ... plzzzzzzzzzzzzzzz help me
Dear Aditya,
Same problem with me. Seems Gameloft HD games are not compatible with NEO V. Dont know what SE guys have done with this downgraded version. On NEO international model all these games are working.:smileyangry:
And even on Gameloft site NEO V is not listed. I think its related to apk files only and in future the same will be available Hope for the best
Hugely disppointed when I see 9mm, Battlefield, BIA, Nova2, Assasin Creed not working on Neo V. Even these Gameloft guys is also restless not even bother to respond the query posted for NEO V.
Working Games successfully installed
Asphalt 5 HD
Real Football 2011 HD
Splinter Cell Conviction HD (Stuck in the 1st stage)
Gangster
GT Racing Academy HD
PES 2011
Regards,
Pramod
^^Will you please try some other non-gameloft games? try Roboto or biofrenzy type games. Check biofrenzy specifically. Please check them and respond ASAP as I almost bought this phone but stopped after reading such comments.
Good (and wird) thing is that this site itselft doesn't show neov as an option itself. I just registered here and it neo V was not available in "select phones" catagory. So, I guess its b/c the device is quite new.
Too bad galaxy W didn't release here
hiee pramod
thnx 4 ur rply ...and where did u downloaded des games ?? are dey 4m android market ??
at parmod, yes you are right with your statement..compatible versions..
i downloaded spider man in my arc thru apk file and same result as the above users dark screen but then saw another arc user playing the same game..
so neo v supports the game but you have to either purchase it from the android market or find the correct apk file..
also just go to market.android.com
enter you gmail account and sign in ( the same account in your phone )
then search for spider man in the market and below the pic tell me whats writen
it wil be either compatible or not compatible..try it
