Apparently the front camera is not working ...
tested before the update everything, including the front camera and was working perfectly ...
Now after the upgrade just can not use ... I have no option to select it and still can not activate the facial recognition it gives error when configuring ...
This is an English only forum
translate.google.com
cristianmartins wrote:
Apparently the front camera is not working ... tested before the update everything, including the front camera and was working perfectly ... Now after the upgrade just can not use ... I have no option to select it and still can not activate the facial recognition it gives error when configuring ...
repair your phone with either SUS or PCC and see if it works
Update Service (SUS)
I'm doing the recovery, once you say what happened
let us know if it solves this issue
Nothing ...
I lost everything I had installed and did not solve the problem
The error it gives is
Could not start the "unlock facial"
but if you unlock the phone the front facing camera work?
gives me no other option, just do not set the lock face ...
addition of the opinion that the camera does not exist, because nothing else recognizes ...
which did not happen before the upgrade
my question is once you unlock your phone -> open the camera app -> menu -> front camera does it work?
Don't forget to mark the Correct Answers &Helpful Answers
No, the front camera not working ... That was trying to say, or the application of the camera she aprece as before ... does not give me more option to select the front camera
