My 10days old experia e is experiencing problems regarding the indicator light.it has stopped working for text messages and calls.It only works for bbm,whatsapp and email indicators.Please give a solution.
Tell us if issue is the same booting phone in safe mode
Method 1
did u tried switching stamina mode off in ur cell...?
How do i switch off the stamina mode?
why do i require the safe mode ?can't the light perform straight in the normal mode?
Notification light bug could be caused by a third party app that you installed
Safe mode loads only stock apps. Make this test.
For stamina mode. If your phone have this feature and is enabled ALL notifications are disabled not only sms and calls.
To check if you have stamina mode go to settings>battery.
yea i checked.The issue persists in the safe mode too.and i don't have a stamina mode.please help.do i need to take it to the customer care?
Before go to the nearest sony service center you have to try:
- Firmware repair following this guide: http://talk.sonymobile.com/t5/Xperia-Ion/Detailed-Software-Repair-Instructions-using-Pc-Companion-Wi...
- Factory reset
If same issue after these two steps, go to a service center
