Hi
I move the file /system/bin/sh to /system/bin/sh.old and I can't to rename thise file becose the partition is only read and to change to read/write need /system/bin/sh and ofcouse don't fine this.
The tools for reset my movil (PC Companion) don't works
Coul you help me??
Coul you now if exists any form to copy the sh to /system/bin/ ? , i tried use the "adb.exe push sh /system/bin" but don't works.
What application did you use to make these changes? Maybe you can check with them if they have a revert option or utility to use.
You may want to give use a call if all else fails to look into having our technicians take a look, however be aware that software tampering may not be covered under the warranty.
