I can't connect my smartphone to PC using multimedia mode. Drivers for USB devise MTP can't be installed. Some time ago everything worked normally. I use Sony PC Companion v. 2.10.053. Please help me.
How do you connect? USB or WiFi?
1. Try connecting using PC companion.
2. Try a diffrent usb port
3. Try uninstalling and reinstalling PC companion
USB. I tried all of this, but it doesn't help...
Same happend me.. I don't understand why?
Also at last, try a different PC to check where is the problem.
Here are the steps I took to fix the problem:
This is a workaroud, however the post is still a bug that should be fixed by the PC companion developers, That software has a bunch of gaps.
And please SONY GUYS! IMPROVE YOUR ERROR MESSAGES, put a code or something to make the diagnose easier.
Hope this helps,
