Emergency Calls only
Gillyboo
Hi Folks. I have an Experia E3. The screen is locked onto Emergency calls. It is recieving data as it pings as normal so I know the SIM is working. I have looked at previous messages and note that PC Companion may be able to repair my phone however I have not managed to back up my photos and these will be lost of I complete this process. Is there any other way I can restore my screen without losing my stuff? I have tried to reboot by switching the off button at the back and no luck.
As an aside, this happened after I put the phone into my bag alongside a Hudl. It was working perfectly up to that point and indeed I was in the process of data transfer etc when I had to stop what I was doing and leave the house in a hurry.
Any help is greatfully appreciated.
5 REPLIES 5
Thommo
Genius
Did you have a screen lock pin or some other security setting which may have been entered wrong causing this
Gillyboo
Not as I recall. It was 5 days ago that this happened and I was doing all sorts of stuff on the phone. I did set a pin that is for sure but it is not one I would put in by mistake.
Thommo
Genius
I can only assume this is the cause for your locked device as it is usually the reason - I can't say for sure this will work but you could try logging into MyXperia from a Pc then select you device then select Lock and type in a 4 digit pin which will then need to be entered onto your phone - If it works then great and if not then I'm sorry to say but a system repair will be required meaning all data will be erased
Gillyboo
OK. Thanks I will give the former a go and see what happens
Gillyboo
So... Full system repair it was. Took all night as my internet is really slow. Now starting again. Oh joy......
