hi all, can anyone show me how to customized the elm equalizer settings?
thks
syeap
If you go to: Main menu--Media--Music--from options--Settings--Equalizer--Manual or Preset: Does your phone have these options?
hi dr chris, the equalizer menu don't have user customised option, when i was using W660 it has this user custom option, hope u can help me out?
i would like to set bass & treble & voice to max, any idea how? thks
hi again dr chris, like to let u know that this ELM model have only preset option but no custom option
Only a software update with this as an added feature can sort this out.However, in the absence of this, if you go to Getjar.com you can download KD Player, a free Java music application which works well with playlists you create and has custom, as well as preset, equalizer settings.Hope this helps.
hi dr chris
where can i dl elm updated software which has equaliser custom feature?
i've tried KD player but it does not work, more help ? thks
What exactly do you mean KD Player does not work? Are you having trouble installing it or using it after installation? I was talking about a software update that may have this feature.If you have the latest software in the phone and it doesn't have manual equaliser options, then you need to use an external application.
