Easy Advanced task killer put phone in pin-loop
Pasi71
I have X10 Mini
I installed Easy Advanced task killer from market, it worked fine to start with then I thought I´ll reboot the phone to kind of get at fresh start.
The phone starts, loads up, and then I enter the pin code, it goes on for a bout 5 sec and then the task killer kills something, and then the phone kicks me back to pin screen again before I can do anything like, kill or uninstall the task killer.
I give the pin again and in about 5 sec Im kicked back to pin screen again, does this over and over,
I also installed a battery saver plugin that the taskkiller suggested to me. Could that affect things?
So now Im caught in this enter pin code loop.
Suggestions?
I´d rather try something else first than restore via SEUS.
3 REPLIES 3
Pasi71
Ok I managed after many tries to have enough time to navigate with 5 sec intervals to settings menu and turn off auto optimation off memory.
Ive added recommendend things and front services to Ignore list, but everytime it does the optimate memory thing it kicks me to pin screen even if Ive been in the phone a while.
This makes this app totaly unusable, cant find any setting to make it work
Johan
Check if you can boot the phone in safe mode and uninstall this app. Then check if the PIN problem remains.
To boot X10 mini in safe mode power off the phone. Power on and when the text Sony Ericsson appears you press and hold the menu key until the phone has started.
Pasi71
Thx, I have solved it as you can see in reply above yours. Took the app off, couldnt get it to work
