DUAL SIM PROBLEM
SARATH
DUAL SIM PROBLEM
I AM USING TIPO FOR THE PAST ONE MONTH AND I HAVE A PROBLEM WITH MY DUAL SIM
WHENEVER I CONNECT TO INTERNET WITH ONE SIM THE OTHER  GOES TO OFFLINE AND DISPLAY(NO SERVICE ie.,no signal)
AFTER DISCONNECTING THE INTERNET BOTH SIMs ARE ACTIVE.
PLS SUGGEST ME WHAT TO DO
6 REPLIES 6
Jake-SonyXperia
This could be a software issue, I suggest you try a software repair first and then advise if this has resolved the issues. I have supplied a link below that will allow you to achieve this task.
PC Companion:
http://www.sonymobile.com/global-en/tools/pc-companion/
SARATH
AS PER YOUR REQUEST I REPAIRED MY S/W BUT STILL I AM FACING THE SAME PROBLEM.
EVEN A 2000RS NOKIA DUAL SIM PHONE HAVE DUAL STAND BY DURING INTERNET
BUT SONY RS10500????
murthy_dhavala
Even I am facing the same problem. I have purchased Xperia tipo dual just 3 days back.. even after reinstalling the SW, problem persisting. what to do to resolve this issue?
Jake-SonyXperia
With the information supplied, I suggest that you take the handset back to place of purchase, as they should be able to supply a resolution to this issue. If this is not an option then I suggest you contact Sony Xperia Support within your region for service centre contact details.
star_apj
EVEN I AM FACING THESAME PROBLEM
dheerajn
Even I am also facing the same isue with tipo dual
