Downgrade to 182?
asplundj
New
Downgrade to 182?
Does anyone know if it's possible to downgrade from 184 to 182. Wifi is working really bad after the update to 184. I have also tried a software repair using PC Companion but the problems remain. I get a fairly good signal (two dots) but the connection drops frequently and I can't check e-mail because the internet connection never stay alive long enough. It reconnects automatically after a short time, most of the time. I did not have these problems using 182. And the motorola defy+ in the household works fine on the same network. wifi works a bit better (it's even usable) at work than at home.
Because of this I would like to downgrade to 182 to see if it helps. I don't want to try another repair because I have done that already
Any other suggestions?
2 REPLIES 2
asplundj
New
I've now set a static IP and it now seems more stable. I have only tested for 30 min or so though. Strange that this was not needed with version 182
finch1221
If u want to downgrade it u should set it to factory setting but I dont know what else factory setting will do
