You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
Thank you for your advice, but Im not IT person:/
I have just PC companion in computer and you said to make sure pc is not connected to computer. Im lost:/ Probably will have to take it the sony store and hopefully they will fix it.
Keep us updated.
Thank you, I will. The only problem is i bought it in Czech Republic but live in London. Hopefully it wont be a problem.
I managed to do repair as you said, but it didnt help either. I guess the phone is faulty. But I have been told that the phone wont be fixed in UK cos it wasnt released here. Have to take it back to my country. But thank you for your help.
Contact your local sony team as we don't have further info on this.
