Disable sound playing when placing phone in the Dock
ronnikn
Hi.
I just got a Z3C.
Is it possible to disable the sound playing when placing phone in the Dock
30 REPLIES 30
tors
Yes!
You will want to look at the pre-installed Smart Connect application.
http://userguide.sonymobile.com/referrer.php?region=za&product=xperia-z3-compact#!Smart-Connect.html
ronnikn
I have looked through smart connect and cant find any solution specific for the dock.
To claify what i Mean.
When i put the phone in the Dock it plays a sound/tone and that is what i want to disable.
SergioPL1
Hi. Maybe try this:
Open Smart Connect
Tap on 3 dots button in the top, right corner then select Settings.
Uncheck "Notification" and "Vibration".
Does it help?
You can also try Settings / Sounds and disable touch and screen lock sounds. Maybe it is related to this.
tors
Aha, I misunderstood the question.
I haven't managed to find any settings to turn off that sound.
The Smart Connect settings for Notification and Vibrations doesn't seem affect this sound.
It works to change the Sound settings manually (vibrate or silent) before putting the phone in the dock though.
tors
Oh,
tried it some more and the combo of unchecking the settings in Smart Connect and adding a Sound Mode Silent as a Charging Dock event makes it go silent and no sound is heard when put in dock.
It is then kept in silent mode however...
ronnikn
Thanks for trying guys Slightly_smiling_Face
Seems I just have to get used to the sound/tone...
SergioPL1
Which operator version of the phone you have?
Could you record (from other phone) a short video of this sound and put it here (or to YT or any other service)?
IanWood1
I would also like to disble the charging dock noise but leave the phone in NON slient, so phone calls get through for instance. I am surprised it is so difficult to turn off.
SergioPL1
What do you mean by dock noise?
