Disable safe mode in xperia M
Rahul2430
New
I am using xperia M it is showing safe mode on the left side bottom corner. Its volume button is not working. Phone reset done many times. asc person saying motherboard has to be change. Anyone having any solution plz update.
Tags (1)
3 REPLIES 3
Thommo
Genius
Try performing a system repair using Pc Companion as this will often fix issues - This will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
If that fails then you need to either return your device to the place of purchase or contact Xperia care http://www.sonymobile.com/global-en/support/contact-us/
ra23
Problem is that, I can not use volume key as it is not working,
Plz suggest another process..
profile.country.RO.title
_alexdon_
Perform a factory reset from the device itself or stop by a sony service:
alexdon
