Difference between Xperia SP C5302,C5303,C5306...?
sanunath_gg
There exist 3 version of SP na? C5302,C5303,C5306....What is that..? N difference between them..? confusing.... Help me friends..... Slightly_frowning_Face Slightly_frowning_Face
31 REPLIES 31
islandM
hey,
I just recently bought this phone and was initially wondering about the same thing.
Check this website - http://www.boeboer.com/sony-xperia-sp-user-guide-specs-manual-5303-c5306/
The difference is the frequencies that the three different models support.  Make sure you get the model that supports your local provider's specifications.
For me, I'm with AT&T in the US.  I don't need 4G.  So I got the C5302.
florenclondon
my c302 camera, it takes picture with many noise n jitter
SatishAryan
turn off the shutter sound in camera app settings
ShadowShen
anyone know the price in US for C5302 from the sony center?
itzimu
Do you know that is better? c5302 or c5303 ? And which version get update fast !
Ashroft98
Enthusiast
C5302 does not support 4G LTE(Very High Speed Internet) while C5303 supports 4G LTE.So Xperia SP C5303 is much more expensive than Xperia SP C5302.For the update question,it depends on which country you are from.If there is an update,then it will be available for all C5302,C5303 and C5306 but different countries will receive the update at different date.
nbasalkar
I'm from india ....
I'm going to buy xperia sp ,so which model should I buy ,is it c5302 or c5303?
samarth05
The difference of the three varients of Xperia SP (C5302, C5303 and C5306) are only that of the Network. If you did buy C5303 or C5306 it's of no use as LTE Service is not available in India... So I think you should go for C5302 cause the other two varients are of no use. Only if you travel Internationally then the other two varients (C5303 and C5306) are of use..
Remember That all of the Three Varients have Same Configuration except network... C5302 also supports most networks across India.
You made a great Decision in thinking of Buying Xperia Smartphone!..
WELCOME TO THE XPERIA FAMILY!
PROUD TO BE XPERIA OWNER!!
HIT KUDOS IF I HAD HELPED YOU..
