Dead st27i screen- anyone, HELP Pls & Ta!
jnnyj
Hi all, am I the only 1 thats got stuck with a Go with a bust screen( cracked, just wont work)? Tried everywhere and cant find any comment/post related to a solution. Goin mad at this stage!!:smileyplain:
10 REPLIES 10
jnnyj
That should read NOT cracked - told ye I'm goin maddddd
kenw
You try pressing the power button and the up volume, this a phone restart sequence.
jnnyj
tried it loads, not working?
seahorsemoves
1. check battery if its empty Slightly_smiling_Face if its ok then try step 2
2. hold the power botton and volume up arrow Slightly_smiling_Face
hope this help
Simply_Jesse
Same problem... sudden NO SCREEN DISPLAY...
SONY SUPPORT GROUP... ANY IDEA PLEASE????
Sam
Legend
Legend
Try running a repair (yes this can be done with the phone powered off):
and install it on your PC.
4. Phone Software Update.
5. Start.
6. Repair Phone
7. Continue
8. Accept data removal
9. Next
10. Wait for prepare
11. Select Phone
12. Follow the connection steps
jnnyj
Ta loads, but done all this to death1 Need to find something else.
Simply_Jesse
Yes, it didn't solved the problem with my fone either...
Sam
Legend
Legend
To be honest if you have both done this and have still had no luck then I can only advise that you return the handset so that it may be assessed by an authorised repair agent.
