Dead Battery
Eless
Dead Battery
Hi all.
I have a probelm with my ION xperia, well It does not charge a bit, just the led in on and chargo upto 1-2% all day long.
I have tried plug to PC and the home, no improve nothigs.
Can u help me?
Maybe should change the batttery?
Please help me.... thanks
2 REPLIES 2
profile.country.RO.title
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
alexdon
Jake-SonyXperia
Hi Eless,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
In this case, you may be looking at a hardware issue, I would suggest that you get the handset to a service agent for assessment. Please contact Sony Mobile directly using the link below.
