Data stops working automatically
KKS
This is a peculiar problem with my Sony Xperia C. Since I travel a lot and I need my emails all the time, the Roaming & Data functions on my phone are NEVER switched off. However, whenever I'm roaming, after 2-3 hours, the data stops working abruptly. Both DATA & ROAMING are still enabled in the phone settings, but all data stops working.
1.) I know its not a network problem because 1 week ago, using the same SIM card, everything was working fine on my 3 year old Nokia 5230 even on roaming.
2.) I know its a phone problem because if I restart the phone, the data starts working properly again. Even without restarting, if I switch on Airplane mode & then switch it off, it starts working again.
3 REPLIES 3
Anand_95
It happens when stamina mode and low battery mode is activated.. When your battery reaches desired value set in mode it stops the connection.
or maybe your data limit is less increase it to max. In data usage
KKS
The phone was at nearly 86% battery. Nowhere near stamina mode. I checked the settings & data limit has not been ticked. So there should be no problem anyways.
This problem is not there in my home network. Happens only while roaming. Unfortunately, I travel a lot.
Praks68
I am facing the same issue. This is an issue with the fone. I have not kept the fone in the stamina mode but still the data network disappears and connects automatically.
