Since the latest update (12.1.A.1.201) the data roaming does not work.
I was in a foreign country and had the roaming options enabled. But no app was able to send/receive data - and the browser said "you're offline". I called my provider's hotline and they checked their part - all was working.
how about
settings > more > internet settings ?
In German I can't find "Internet settings" in the "more" submenu. But if you're talking about "Mobile networks", I enabled "Data enabled" and "Data roaming"... Back in Germany, the mobile internet works perfect again...
There was no problem with data roamin before the update.
Settings > more > Internet settings should be underneath Mobile Networks, if not then
settings > Xperia Connectivity
I only found Settings > Xperia > Internet Options - but there I only can download the settings for my provider. And these already were correct.
Sorry to hear that, perhaps another user can replicate this issue
Did you also contact the operator in the country you were in? To me this sounds more like you were not allowed to use data with your SIM by the operator in that country. If this should happen again, check which network you should use and try selecting it manually under Settings -> More -> Mobile networks -> Network operators.
