Ok,if you say so.
Now u got idea what removed apps is im curious about the android os what is that
Now there are 2 things which are ambiguous.
Remeber, the removed apps refer to the apps which you had downloaded using your data and they were later unistalled by you, so this solves your problem, most probably you downloaded or your son/daughter/wife/gf/bf downloaded an app and unistalled it.
If this is the case the apps which were downloaded on your data and then were removed, here is your answer
Accept as Solution and Gimme A Kudos:) If I have Answed Your Question
CarbonoAtom:)
Also the MX player was unistalled from what I see, thus also added on to your data.....:)
