I see issues with some basic features as follows - Can anyone confirm if this was seen with their phone?
1. Unable to use Bluetooth (not able to make the phone visible to connect with any device). I see this as one of the primary features of smartphone especially when I need to use a bluetooth headset for making calls.
2. If I try switching Bluetooth ON and OFF, after few seconds, I see atleast one of the following different issues every time:
a. The phone crashes and restarts
b. Phone crashes on incoming calls. (stability of the phone).
c. The Bluetooth button gets disabled and not able to continue further.
3. I see similar issues when I enable Wifi as well.
If anyone has seem similar issues, please revert back. I have not installed any apps on this yet.
Thanks,
SJ
Hi
by default your phone is not visible for other devices.
go setting->bluetooth
and turn your bluetooth and tap in your phone icon.
it will be visible for 2 min. you can change visible time in setting.
other problems are not normal. first reset your phone(factory reset) if it not work. repair it with SUS or other softwares.
