Couple of issues
babinaba
Couple of issues
I've just done the upgrade to my phone and I've had a couple of problems, I don't know whether it's just teething problems or permanent.
My phone is randomly turning itself off - not restarting, I have to restart it myself, it did it in the middle of the night, luckily, I'm a light sleeper so the vibrating sound woke me up and I turned it back on. Also, I've had random vibrates for no reason - no notifications for anything, it just randomly vibrates - again, I can't have this happening in the middle of the night as it'll wake me up. Anyone else experienced these? I've gone through all the apps I can think of that would have notifications to see if I've turned off getting a notification in the bar but not the vibrate and nothing. These are the two things annoying me most at the moment.
I have found it a bit laggy but nothing more than what it was before, my battery has certainly improved, normally on airplane mode overnight it used to lose about 20% but last night it was only 4% loss.
Thanks for any help you can give with the switching off and random vibrates!
4 REPLIES 4
Alexander1
I would suggest that you try to boot your phone into safe mode to see if the behavior may be related to any 3rd party app that you have installed in your phone:
Danial-mach1
Leader
@Alexander wrote:
if no succseed then try software repair via SUS
but make back up from internall storage if you want
babinaba
Thanks - did the repair and it seems to be ok now. However, I now have an issue with the wifi connection - says it connected but when I try and connect to anything it says there is no internet access (the wifi is working fine on my tablet and laptop so it's not the connection - seems to be solely related to the phone). Any help on fixing the wifi would be great as I've only had this problem since the upgrade. Router has been restarted twice
Thanks
Danial-mach1
Leader
check proxy and vpn setting on your phone
