contacts crashed
AndreiP
contacts crashed
Hi everyone. I have an xperia zip 2, and I am experiencing a problem with my contacts app. It crashed, I have no contacts and I cannot make calls but I can receive them. I closed the app, cleared the cache, still nothing. What can I do?
2 REPLIES 2
Thommo
Genius
Try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
Jake-SonyXperia
HI AndreiP,
Discussion Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines
Did you also clear the data from the Phone and Contacts apps? clearing the Cache is fine, however you may not be able to resolve this issue with just clearing the Cache make sure to Clear the data on the app.
Let us know how you get on.
