Contact problem
Farhood
Contact problem
I have about 1000 contact in my list, and I have problem when I open contact list. Opening is very slow with delay. Also I can't save new contact to Google, only on phone and Hotmail.
When I save new contact to Google it will lose.
What is the solution?
Tags (1)
3 REPLIES 3
Ashroft98
Enthusiast
About the lag on contacts,try backing up the contacts at your SD Card/Sim card by exporting it first.
Then try this
Go to Settings > Apps > Swipe the left twice to "All" sections > Locate and click on "Contacts" and press clear data.
See if that improves.If all the contacts is lost,then just import it from SD card/Sim Card
You might want to clear the call history
Domza
Had the same issue, contacts would load but when I selected one it would not show the detail.
Cleared App data and tried again, workedfor approx 2-3 minutes and then back to slow ness. Contacts load quickly enough but opening any contact takes approx 20 sec to show the detail.
Using a third party dialer and contacts app is a work around but surely a core function like this should just work...
Will watch the forums for updates and solutions.
