Hi, I hope someone can help... I did not have enough spare storage to my device so bought a SanDisk 16GB Micro card and installed this (as a side-note I was making extra space to install the new Software Update and did not want to remove anything from my device, simply transfer some things [photos etc] to the Micro card])...
OK, a quick trip to Tesco and had my card, installed it and there was an issue transferring my data (some 'interruption message' - cant quite remember it exactly), but dod 'Google' it and the general advice was to back-up the device and perform a Factory reset, and then restore from back-up.
Device backed up OK (using Xperia Companion for Mac) and phone was suitably reset.
Restoring from back-up gives me a spurious problem! When I open my call log all the names present themselves correctly for a few seconds and then revert back to the numbers almost immediately. After 10 seconds my entire call log is simply numbers, my restored messages are number-aliases not names and my contacts list is only 7 long (my prior one was over 200!). If I choose to restore the 'contacts only' through Xperia Companion (leaving my call log open on my phone), within 30 seconds I see my contact list names reapper instead of the numbers. I follow the on-screen instructions and restart my phone, open the call log and see them revert to numbers in front of my eyes again... I have done this a few times now...
So I know the names are stored correctly as they appear correctly (albeit for a short while) but what am I doing wrong?
My iMac is fully updated (I'm a stickler for software updates, hence this whole process in the first place!)... and my phone was fully updated before trying this...
I have scoured the forums and followed other advice (checking filters, Settings>Apps>Contacts>Force Stop [& restarting]) - nothing is working!
I use my mobile for my work and am seriously looking at ditching this for an iPhone (my previous Z1 lost my contacts following a software update so I bought a Z2!)
Thanks for any help that is available!
Si
If it helps.... I have done this for yet another time and I am getting the following information upon completion of restore:
The following content could not be restored:
Other
bbc.mobile.news.uk
Settings
Hope this helps!
Si
Oh... and none of my apps are reinstalled following a restore! (not sure if this is normal (they do with Apple devices))
If the backup was done through XC you should be able to restore most of your data, BUT Android doesn't support a backup/restore as iOS.
Could you check the phone app > contacts > menu > filter > select everything.
Thanks,
I am trying to restore my data to an existing Xperia Z2 - the data is there, but disappears...
I am only considering the iPhone as I have lots of Apple devices and they just work... if I have to start from scratch for a 2nd time I would like to do this on a device that I don't need to do this again...
Thanks
Si
The backup data is from the Z2... I no longer use or have the Z1...
I backed up my Z2 and then restored the same device, updated the software and restored from backup to the same device
Thanks
Si
I have - this is definately not the problem...
