connection time out
connection time out
hi! i bought this phone yesterday, everything is doing great except that everytime i connect to a wifi it takes time to load even if the wifi signal is very strong and also everytime i go to the android market it always says connection time out, kindly help me on this...thanks!
3 REPLIES 3
gwhispererz
Hi, since you have just got your phone yesterday, I assume that there is not much important stuff inside?! I would suggest Factory Data Reset phone first to see if it helps. Goto Settings>Privacy>Factory data reset. This will erase phone data completely (SD Card not affected), depends on your requirement to backup.
i already did the factory data reset, at first it worked just fine but then later on connection timed out again, also when i log in to facebook or twitter it takes time to load and sometimes it will say an error occurred during sign in Slightly_frowning_Face
Aimee
Enthusiast
Does this happen with more than one Wi-Fi connection? Do you get the same issue if you connect using 3G?
