Hello All
I have a problem with my mini pro that the camera turns on all the time even in st by mode. If i'm writing a txt it's turned on automaticly and also when I'm surfing on the net.anyono recognise this problem? i just got the phone back from service yesterday ,but they could not find the fault..
Did the service centre run a software update? If they didn't you could try that yourself by using either PC Companion or Sony Ericsson Update Service.
The only other thought is do you have a cover on the phone that may be pressing the side button and triggering the camera to come on?
If none of these things work then I suggest you contact Sony Ericsson direct just find your local number from this list...
