Charging Problem
metalyan
Charging Problem
Hello. I have been using Xperia Z1 for 4 months. I think it takes more time to charge the phone compare to past. I wait almost 3 hours to load the battery from %10 to full. Is it normal? I use original USB cable and charger, and the system is updated. Hope that i can compare to another person.
9 REPLIES 9
profile.country.RO.title
_alexdon_
Do you have any task killers,battery savers? Do you use the phone while charging?
alexdon
are you charging through a car charger? computer? are you playing games while charging?
metalyan
I don't even know what task killers or battery savers are. Slightly_smiling_Face I don't use the phone while charging. I'm charging through home socket.
Thommo
Genius
Does it take as long to charge when turned off - I'm thinking you may have more apps running in the background from when you 1st got the phone making charging time longer
Do you keep wifi on perhaps constantly syncing uploading/downloading data?
metalyan
I've never tried to charge the phone when it's turned off. Next time i will try. Even if there are some apps running in the background(i can't see any apps), it doesn't make sense to wait for 3 hours.
metalyan
Yes, wifi is also turned off.
Phy
Legend
Legend
Boot on safe mode and check how long it takes to charge.if it doesn't take as long then its an app creating this problem
How to boot on safe mode.
metalyan
Thank you for all of the replies. After i try the safe mode, i write here again.
