Charging problem
Azmath
Charging problem
Need assistance urgent!
I don't know, suddenly in the morning when I kept my phone for charge, suprisingly it wasn't getting charged. I have restarted the phone, done all those little things which is said by people, nothing worked.
Tags (1)
3 REPLIES 3
Alexander1
Remove battery, SIM card and SD card. Put back the battery and try to charge without the cards inserted. If the problem persists, I suggest that you try with another charger.
Azmath
I tried that. It charges at times like for a second or 2 then stops. What to be done?
Alexander1
Have you tried a different charger?
You can try to reset your phone to see if that helps. Otherwise I suggest that you have your phone examined by a service center. Please contact your local Xperia support team for more information:
