Hi all,
I've had my Xperia Z for about two months now, great phone very happy with it except for this nagging issue. The waterproofing flap on my charging port won't close properly any more, everytime I close it the flap would pop out again after about 30 seconds. It's quite annoying to have it flapping about all the time but obviously it also means that my phone is no longer waterproof. The flap itself looks like new and the seal hasn't been damaged or anything, it just wouldn't stay in place. Is this a common problem? Should I send it back for a replacement?
Hello schan,
I am having the same issue with the earphones flap.
I have tried to force it to the original position by adding a sticker for a couple of days, but when I remove it and open it, it will pop out again.
I am thinking of bringing it to an Official Technical Support point, but this sounds stupid to me as I have had the phone just for a couple of weeks.
I don't want to think what could happen in one year.
I would have to advise returning the phone so that it may be assessed by an authorised agent sorry.
Hi all,
I am having the same issue with my Sony Xperia ZR. The flap is not closing properly, it pops out...
Hopefully the same would be resolved at service outlet.
I'm also facing this problem with head phone flap.
Will this problem cover warrranty?
I got the same issue on my very new ZR (2 weeks).
At first I found the flap quite efficient then I started to play with my new toy so I charged a lot, forgot about the flap...
Now that my usage is more reasonable, I noticed the flap start to pop up after a few second.
It stays inside but clearly it s no more waterproof and above all it s UGLY!
I tried to clean the port as advised in another post on xperia care but it was only a bit better.
Wait a few second and it s out.
I think it comes from the connection between the port and the small rubber/plastic oval that enable the water protection.
As cleaning with towel... didn't work, I took a small sharp knife and I gently rubbed the rim of the usb port on the phone.
Of course be very careful. I did it very gently with no real hope it will work (I was ready to go to sony).
I just wanted to be sure it was total clean and finaly................ it worked for me!
I just hoped I won't need to do that too often...
same here. both flaps do not close anymore.
after a couple of months already.....
Hi there,
My earphone flap on my Experia Z doesnt stay closed either and its less than 12 months old. Where can I take it Darwin to get it fixed?
Thanks
