Charging animation problem still present in 12.1.A1.201
XperiaNow
The problem with battery animation when Xperia SP is switched off and charging is still present.
When I press the power button once, the animation appears. Every other time only the backlight of the screen is lit but there is no battery picture in the middle.
Firmware is 12.1.A.1.201 1272-3354 Central Europe 3. The same thing happened with 12.1.A.0.266 1272-3354 CE3.
Interestingly enough, 12.1.A.0.266 1272-3352 Central Europe 1 doesn't have this bug. I flashed that firmware over my CE3 on Saturday and pressed 6 or 7 times the power button and battery charging animation always appeared.
With .201 CE3 I can finally run Antutu benchmark. In previous version of firmware .266, Antutu crashed at 21% of test.
XperiaNow
Battery charging animation when Xperia SP is turned off and on charger is NOT FIXED.
I turned off Xperia SP. Plugged in the cahrger. The charging process started and battery symbol on screen appeared. The screen turned off after a few seconds (this is normal). After that I pressed the power button 5 times in a row and battery symbol appeared only twice while other three times the screen remained blank with background light turned on.
So, no progress here when compared to .201.
