Change notification volume separately with ringtone volume?
SnArF
Hy im using a Experia Z1
1 - Hello i want to know if it is possible to adjust the sound from the ringtone and media separately.
I want my media volume off at night (sms / email / whats-app etc)
BUT NOT MY RINGTONE in case of calls regarding my work.
2 - Is there an app to change it easy wich a can place on the main screen ?
i have tried the slider app which I had placed on the main screen but this app did not do it separately also.
3 - if it cant be done sepratly is there a change that sony is going to change this in the future?
with regards Frans
3 REPLIES 3
Thommo
Genius
1.Ringtone and notification volumes are set as a unit and not separate
2. You will have to check the Play store for 3rd party apps to do this but as I don't use any then I can't say but if your phone is in Stamina mode and set to not wake or sync in the background then you won't be receiving notifications unless you wake your device
3. I'm not aware of any changes but as we are a user support forum then we aren't privileged to this information
SnArF
Tnx for your reply,  i tried  to find a app but did not sucseed
I will have to accept the fact that it is not positie to set both
Volumes appartement.
With regards Frans
SergioPL1
There is a way to do that. Not as convinient as setting a slider but possible.
You need to have audio files for your ringtones and use free app on your PC like Audacity. Then adjust volume difference in ringtone and notifications sound. Then put it into smartphone and set overall ringtone level. Notifications will be louder or quiter depending of what you did with the files.
