Cedar - Gmail configuration
I am unable to setup my default mail client on SE Cedar to access my Gmail account. The phone tries to connect and gives an error "Server not found". My phone's internet connection works fine, and my Gmail account is configured to forward messages to mail clients, as I am able to use 3rd party mail apps like Mobiquus.
14 REPLIES 14
I tried both, first did a master reset - reset all and then did a repair. Tried to cofigure mail client after either procedure, no luck.
Dr_Chris
In that case, I would suggest configuring an email client for a different email provider and see if the same thing happens, in order to give you an indication of whether it's a general problem with the phone or just specific to Gmail.
You might also want to post the Gmail settings, so that I can compare them to the ones on my phone and see if there are any differences.
I tried configuring the mail client for my Yahoo mail account, exactly the same problem. The settings for the Gmail account -
Incoming: IMAP4
Server: imap.gmail.com
Encryption: SSL
Port: 993
Outgoing: SMTP
SMTP authentication: Same as IMAP4
Encryption: SSL
Port: 465
Dr_Chris
Those are the exact same settings that my W995's email set-up wizard downloaded and they work fine for my Gmail account. Since your Yahoo account is also giving you the same problem, there are appears to be an issue with the phone's internet connection as the error messages "cannot connect to server" and "server not found" (which I also get occasionally when trying to access emails) would indicate that. I can only suggest you redownload your mobile provider's internet settings and failing that, try a different mobile provider or different setting as in some cases, you can actually use another provider's internet settings, depending on whether they are running off the same network, i.e., Virgin and Orange, which both use T-Mobile.Which provider are you using?
I am in India now. I have tried 3 operators in the past couple of days, same problem on all of them.
