Cedar format memory card automatically on every startup!!!
Hello Sony...
I have cedar with IMEI 012611004279923 with following issues::
01 ) it format memory card (provieded by sony and other cards too) automatically on every startup!!!  i lost my important data at needy time..
      i had done all reinstallation...updation etc....
02 ) sony tiwtter app never allow login...its my challenge to sony to make login into tiwtter a/c via its app....for it i had done your ways of updation
03 ) Earphone are OFF...since its just 6 months...one earphone gets off...no warrant regester by sony care...they says its has 6 month warranty... I THINK SONY HAS STARTED WITH  POOR RAW MATERIAL FOR MOB PHONE !!! may be low cost chainese materails........
04) OS software is not hardware friendly....get hanged many times...
16 REPLIES 16
i m saying on 01) issue...
If i use Internet via Cedar and do downloading on memory card..then it get auto format..and if on phone memory then it do not get auto format!!!
Dr_Chris
Then it sounds like a problem with the memory card, although that's by no means certain.As I said before, you need to format the memory card on the PC using a USB card reader, and then see if this still happens.Obviously, this implies that any memory card you use is also genuine and obtained  from a trusted source.
Dr_Chris
You could also test these memory cards in another phone and see if they behave in the same way.
no no i dont get any solution....i have 3 memory cards...all have same issue...Cedar is unable to save download data into them means get auto format....please solve it....!!!
only cedar show this issue..not other phones.........
Dr_Chris
Then it's a problem with the phone, and since you have tried a software re-installation/repair/update/reset/memory card format to no avail, then use your 1 year warranty to get the phone repaired in a service centre.
ok...but i think, now you understand the sony care executive..in India
there is no one form sony that solve it...and no one can LOGIN VIA TIWTTER APP in Cedar
