Hello Sony...
I have cedar with IMEI 012611004279923 with following issues::
01 ) it format memory card (provieded by sony and other cards too) automatically on every startup!!! i lost my important data at needy time..
i had done all reinstallation...updation etc....
02 ) sony tiwtter app never allow login...its my challenge to sony to make login into tiwtter a/c via its app....for it i had done your ways of updation
03 ) Earphone are OFF...since its just 6 months...one earphone gets off...no warrant regester by sony care...they says its has 6 month warranty... I THINK SONY HAS STARTED WITH POOR RAW MATERIAL FOR MOB PHONE !!! may be low cost chainese materails........
04) OS software is not hardware friendly....get hanged many times...
Have you tried a master reset?
yeah i already do so....also update via Internet...currently i am doing study of this issue
So why did you only have 6 months warranty? Normally you would get at least a year, and quite often two years from Sony/SE directly, independently of any warranty by the retailer or network.
I contact to Sony Care...they says its 6 month warranty for every earphone...it in India...but I really felt bad with sony care...
So in India you get a 1 year warranty for the phone and 6 months for the accessories that come with it?
If that's the case, that sounds normal.
very bad .....sony care....!! but before i have w200i ...it was 1yr!!
sony care excutives are dynamic persons...one say its 6 months..another say 1 yr...well but SONY never say correct...they change their policies according to issue....Well what you say about 01,02 issue in my topic.............
Well no 1 issue is more serious, but have you tried formatting these cards on PC (using a USB card reader) in FAT 32 mode, before using them in the phone? If that doesn't work either, and since you've tried both a software update/re-instalation and a reset to no avail, then you need to to send it in for repair, as it should be at least a 1 year warranty for the phone itself, as you can see from this warranty document, taken from India's Sony site for the Cedar:
http://www-support-downloads.sonymobile.com/common/warranty_phones_IN_12.pdf
it will be better if Sony Executive from India will see it now....
for 01 issue
i have a conclusion that
if i do downloads from internet over memory card...so it gets format when i do switch on to phone...but if i download over phone memory..it remains unformate.......:smileyshocked:
what you say?
I don't understand what you're trying to say--all I can suggest is that you have it repaired under the 1 year warranty.
