I can not make calls with my Xperia L
The obvious question is do you have credit on your account or is your network experiencing issues
Try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
What if you try the basic? turn off the phone > remove the SIM card > insert the SIM card > turn on the phone
or boot on safe mode
or get a new SIM card
or repair the phone with PCC
