can't update.
ashleylawless
can't update.
I go to update and it downloads then says can't download.
11 REPLIES 11
Alexander1
Could you please elaborate a bit?
Are you trying to update directly in the phone via Update Center app or are you using a computer?
ashleylawless
Yes I am using the mobile device to update. It fully downloads. But after its finished just before it should install it says "could not download“
Alexander1
OK. Thanks.
I recommend that you are connected to a Wi-Fi network when you do this update. If you already are, I suggest that you try on another network.
You can also use a computer to update the phone:
ashleylawless
Tried doing both. And still nothing.
ashleylawless
Companion says it's not original or something.
profile.country.RO.title
_alexdon_
So your bootloader is unlocked?Then it will notify you about not original software.
alexdon
ashleylawless
The bootloader is I think.
_alexdon_
You cannot install official updates if the bootloader is unlocked.
alexdon
ashleylawless
So,if I relock it. It will update.
