Camera
dimuthus
Camera
My phones camera is not working since last two weeks need urgent help
7 REPLIES 7
manjuboyz
Hi dimuthus
> please give brief explanation what exactly happened to come to the conclusion of an issue
>have you updated the software of the phone , if so is it phone was working fine before or  what ??
>you can try this too
    settings -> apps -> all -> camera -> clear cache and restart phone and try
let us know
Manjuboyz Slightly_smiling_Face
NOTE:
Rate me(Kudos) If you are happy with my Resolution, Thanks Slightly_smiling_Face
dimuthus
The phone was working perfectly also The latest software is there with it
when I go to setting and apps and all and camera The cache button is disabled
manjuboyz
if yor are comfortable with clearing data then you can try to clear data
you might lose the photos which are taken from the phone, so keep back up before doing it
>what happens when you tap on camera screen, does the app itself is not launching or you are not able to take pic ?/
NOTE:
alexrx
Enthusiast
@dimuthus,
manjuboyz is right, just clear data and then Force stop + restart the phone and try again.
Also, have you tried to repair/re-install the software using Sony Update Service or PC Companion after the problem with the camera?
dimuthus
App is not lonching
manjuboyz
Thanks for the information provided
     i believe the camera app which you are using is default app which comes along with phone ???
if so, you cannot download or remove those app to get it fixed, you might need to restore the phone to get all the apps get back to normal
why you need to restore because, its an inbuilt app, if it is not launching then might be some software issues, restoring phone you will be losing all the data (make sure take back up before doing it ), i guess it should fix your problem
NOTE:
alexrx
Enthusiast
@dimuthus,
Re-install the software with SUS.
Sony Update Service
Instructions for backup & transfer
Keep us updated.
