Camera switch symbol disappeared.
Taimur
I have Xperia Z1. It was working fine n had been sitting in drawer for about 6 months. Now I started using it again. The phone works fine but the Camera switch symbol is not there. Therefore I can switch to front camera.
Any solutions??
3 REPLIES 3
Phy
Legend
Legend
Try Clearing the data.
How to clear data on apps.
From your Home screen
1. Tap the Application screen icon.
2. Find and tap Settings > Apps.
3. Swipe to the All tab.
4. Find and tap on the camera.
5. Tap Force stop > Clear data.
6. Restart the phone
Taimur
Thanks for your time. I did what you saiD. But no joy. Still I'm unable to use front camera.
Any other solutions??
profile.country.RO.title
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 80% battery.
alexdon
