xperia z1 camera is having too more noise the bionz proocessing chip is not working well can u fix this problem or not.so many people having this problem.can u fix it or this cant fix.you promote this mobile is having best camera but it giving very poor image its very grainy image.i want to know you fix this problem or not
I don't see anything wrong with both of them. You shot them with full resolution, so there are some little white artifacts in darker areas, but overall they are what they should be.
You can easily get rid of those artifacts by switching to 8Mp or auto. Plus, in 8Mp (both manual and auto mode) you can play with HDR which will make a big difference, especially against direct sunlight.
May I ask what disappoint you about this camera? I am purely curious. I have seen many phones with cameras (including new Samsung/nokia/apple phones) and so far this performs great enough to be on the podium.
Now this is an interesting seen here normally dpr is very critical toward sony but in this particular instance the Z1 came a second to the 1020. As I told you all tech sites will compare the Z1 to the best but what is interesting is that we're rated the best cam on the android platform.http://connect.dpreview.com/post/4485507296/shootout-sonyxperiaz1-vs-nokia1020-vs-lgg2-vs-samsunggal... take a look it's interesting.
and.. you seem to be surprised, are you?
remember guys that when you select the 8mp output for the camera it is still using the full 20mp sensor to produce the image it just has more data to play with and give a perfect output - that is why SA uses 8mp output - it uses a lot of clever processing to produce that perfect image, you can manually select 20mp as output but you have a lot of work to do to produce that perfect image both pre and post process
The key to thinking about the SA 8mp output is that it's still 20mp input but all the hard work is done for you to produce a perfect picture - hope this helps
I have the same problem I can't solve it please I f find a solution tell me
