Hello everyone!
I have an Xpera M and my camera isn't working. When I open the camera app it says "Camera not available" or "Camera has stopped working". This started happening around September or so, and since, I've tried to do everything to fix it, but no luck. I installed a new software update, custom ROM, bootloader unlock, clear camera files... I even tried sending it to Sony Center but they didn't want to fix it because of the bootloader. I didn't drop my phone or anything, so I don't think it's a hardware issue. Actually, today when I opened the camera, it was working fine, but only for a few seconds. Can someone please help me? :smileycry:It's really annoying when you can't use your camera
Thanks in advance!
Try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone
Forget that you can't as your bootloader is unlocked unless you re-lock it using Flashtool - If you want to then download it and install and run then click on BLU and follow the instructions, then you will be able to follow my repair guide
Thanks for your reply! But I have a problem with Flashtool. Can you please tell me what can I do now?
I also tried booting in safe mode, but it's still not working
what were you trying to do exactly?
Re-lock the bootloader
for the camera
1)dial this in your dialer *#*#7378423#*#*
2) go to service test> camera.
3) see if it works there.
And as far as flashtool is concerned, make sure you have all the drivers installed which are necessary for flashtool to run.
When I select 'Camera' it says that the 'Service menu' app has stopped working.
All drivers are properly installed as for the Flashtool.
