Does anybody know how to fix the camera on an Xperia s because when I try to go to the camera it comes up with "Error, Camera not available."
I had the very same problem i upgraded via Over the air update & camera died.
To fix the problem I downloaded software from sony & reinstalled the software from PC with USB cable plugged in the phone. Now phone working fine.
Hope this helps
It could be that the camera for some reason got inactivated.
Go to Settings > Apps > All (tab). Scroll to the bottom. If there are any inactivated apps in the phone, they will all be here at the bottom. If you find camera here, tap on it and then on "Activate".
Let me know.
after i update my xperia s. hte camera doesn't work and it prompted me "error" "camera not available"
i try to update again but still the same... then i try again then i click repair but it is still the same... then i follow your instructions:
"Settings > Apps > All (tab)." and all apps are on. i open again the camera then error again and camea not available... hope you can help me about this problem as soon as possible... needed your reply sir, please
thank you...
You repaired with sony update service or not?
