Deel jouw ervaring!
I am having the problem of getting the error message ' Camera Not Available' when I tried to activate the camera. I need to off and on the Arc for the camera to work. However after awhile the problem comes back. What shall I do please ?
In this circumstance I would advise running either an update or repair via PC Companion or the Update Service. Please follow the bellow link to source the Update Service program for your handset: http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/xperiax10?cc=au&lc=...
I would recommend Sony Ericsson Update Service to update your firmware...
Download it here:
Follow instruction, if showed you have latest firmware, just hit REPAIR button
Hi all!
My story is about that problem:
- Downloadaed and installed Camera 360 Pro
- Started the software, and tried to take a picture
- "Waiting for Fosus" the cam360 pro said, and crashed after a few seconds
- After that no camera apps works, even teh basic Camera app, and get the message "Camera not available"
- Restarted the phone -> Same
- Soft reset without SD delete -> Same
- With SD delete - > Same
- PC companion Repair -> Not the same, but still cannot work, got this message:
(process com.sonyericsson.android.camera) Has stopped unexpectedly.
Im really depressed about thet problem
because that modell was my favorite since it comes out and finally i got it a week ago, but now...i dont wanna give up this awsome camera. Please Help!
Thank you!
BJ (SE Xperia Arc 2.3.3.)
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
try to update with this..
Hi!
Thanks for the fast reply!
I did it but, the update didnt fix my camera's problem.
I don't get it, how can an App kill the cam?
you did a n update with pc companion right..??
just try with sony ericsson update service
its solves the problem if pc companion fails to do so..
also..
if you get the same error even after updating again.. then you have to go to a service centre nearby and get it checked..
you know i installed the same app yesterday
but now i have deleted it
wont take any chance...
i dont know how an app caused this much damage..
if your phone is still in warranty service centre should replace it for free if theres any hardware damage
just to be on safer side dont tell them that it happened when i was using camera 360..just tell them it just happened with the normal default camera..ok..
Thanks for the advices
Done the PC companion version, and the SE update service too, but problem is the same.
I get is checked, maby its hardware damege, thanks for your answers, have a nice day
Hmm keep me updated;)
