Camera LED flash too bright
Hi I recently bought xperia u. After using camra in any light condition if I turn on the flash, it whitens entire picture. It is too bright!
Can anyone plz suggest me how to control this flash? I am not able to use camera in low light conditons as flash turns entire picture white or smoky
W8ing for ur replies
Thanks in advance
13 REPLIES 13
The plastic cover is on the Flash Lens!!
anandtapas
There is no cover on flash LED. It is on camera lense. Pls check up with service centre before scratching LED Smiling_Face_with_Sunglasses
problem solved thanks for support all of u...there is no plastic cap in lens its only a poly-plastic on camera .i only remove it n camera works great..remember dont confuse others plastic cap or polythene cover is different plastic cover attached on flash n polethene coven on camera.please u all only remove polythene behind camera....it is easy to remove within a seconds..
Kumar_GS
I got the same problem. After removing the polythene cover, my camera rocks!
To remove:
1. open the bach cover.
2. you can find a thin polythene sheet sticked on camera lense(it covers the flash partially).
3. remove the polythene sheet with nails(don't scratch lens)
4. you r ready to rock!!  Slightly_smiling_Face
