Camera has unfortunately stopped
xpm21
hey i have a sony xperia m2  fro last two days an error "camera has unfortunately stopped"
to resolve this i had tried almost everything
like restart my phone ,clear cache clear data but still the problem has not been fixed
please someone help me out wghat should i do....guide me plz
7 REPLIES 7
Phy
Legend
Legend
Boot on safe mode and see if you're getting the same camera error. And check if you have enough memory where ever you are storing the camera images, either the Internal storage or sd card.
How to boot on safe mode
How to boot on safe mode on Lolipop
1. press and hold the power key
2. once you get the pop up menu
3. press and hold "power off"
4. Boot on safe mode should become available
Phy
Legend
Legend
If nothing works you can use Sony PC Companion to repair your phone.
http://support.sonymobile.com/gb/tools/pc-companion/
Christofer
Hi @xpm21,
I as well suggest that you try a software repair using PC Companion.
In PC Companion you press start on "Support Zone" > Start on "Update the phone/tablet software" > "Repair phone/tablet" (the blue clickable link in the message) > Follow these steps without having your device connected to the PC.
The software repair will remove all data stored in the phone so don't forget to make a backup in PC Companion before you try the software repair. You can do a backup using the Backup & Restore option in PC Companion.
stina86
I also have this problem.
After Lollipop update camera stopped working. Front and back camera, also flashlight.
Things I have tried:
*repair through PC companion
*safe mode boot
Any help?
Christofer
Hi @stina86,
Sorry to hear that. If a software repair didn't solve this then I suggest that you get your phone examined by a technician at one of our authorised service partners. Contact your Local support for more information on how to proceed from here.
stina86
Thanks for the fast reply!
Isn't there any way to downgrade? Or is there any new update coming for m2 aqua? maybe that would help?
@stina86
There are 2 ways to downgrade your phone
either contact your Local support
or
use flashtool
